Best/Cheapest E-ATX Case?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811123130 $75+$25 shipping. Cooling might not be as good as the NZXT, but it should work well enough, esp. if you don't care too much about noise.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811123152 $90+$25 shipping, 4u
http://www.newegg.com/Product/Product.aspx?Item=N82E16811160009 $90+$25 shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103011 $100, no shipping, almost certainly has better cooling than any of the other cases I linked to or the NZXT, at least as long as the two 250mm fans last. Replacing them when they die (which may not take long, I doubt they're very good fans) may be a challenge, but while they last the case will run nice and cool.
Any of those are valid alternatives to the NZXT.
Gracias for the links, I found more cases after searching both E-ATX and Extended ATX. Seems like you can't specify those when browsing on Newegg.
