Best Case Painting Guide
I'd like to give my case a makeover - I'd particularly like to put a metallic red color on the case (basically I'm trying to get the case to look like the Logitech® MX510).
Any suggestions as far as the best painting guide out there? Thanks!
-FnM
Thanks a'bunch! I appreciate the links, I will definetly use the info for my project - I'll post pictures.
Yes, this is probably the oldest and most highly respected guide for PC painting out there, so I think you'll have success if you do everything right.
