I'm looking to move from air cooling to water in the near future, and also want to get a new case. I want to buy a case now that has room for all the internals of a watercooling system without creating a wire nest (I'm a neat-freak about my airflow in case). I like the PC-71 from Lian-Li, and it looks like you could mount a radiator above the PSU, which would make for a fairly clean install. Any other cases you guys'd recommend?
Ideally I want a case thats:
1. Full-tower
2. slide-out mobo tray
3. front 120mm (or at least room for) intake, with HD mount in front of it
4. rear 120mm (or room) above/below PSU
5. with or without window, but room for one (no handles, etc)
Don't really need any front i/o ports, although that's pretty standard now.....don't NEED a psu, although if it's better than my antec true 430 I won't argue
1. Full-tower
