Best case for PA120.3
Methadras
Not sure where to put this, case forum or this one, but what is the best case so far for the PA 120.3? I can see definitely do a mod to the CM690 to incorporate it or I can go to the Cosmos S and do a little modding there. Any thoughts?
Mountain Mod UFO-2. Has a fan grouping cut and holed to the size of a PA120.3
All of the above plus several others. Whats best is subjective. If you want zero modding and have the budget a Mountain Mod case will do nicely.
For me due to space constraints I looked around and found a mid tower that could accept the PA120.3 and that was best for me. So it all depends on your needs.
Cosmos S won't fit Thermochill's rads due to weird fan mounting holes position.
One other thing MountainMods now have cases that will take 1.2 or 3 pa120.3 rads for the absolute overkill in multiple loops.
