Best case for me?????
markland556
hey all, im looking for a case, but there all ugly or dont have what i want :(
maby some poeple here know of some good ones, the things im really looking for are:
Window
no front door over cd bays
no crappy plastic looking face or anything.
place to mount my character lcd screen (about 3" by 5")
~~Thanks ;)
look up coolermaster, silverstone and lian-li cases. plenty of different models that fit the bill.
Definitely check out this Coolermaster. Its a throwback to their ATCs line which they never should have discontinued. The Coolermaster line has extremely high build quality and fit and finish, as does Lian Li. I'm fairly certain you can get a window side pannel from CM for it. http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-035&depa=1
http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-063&depa=1
At that price you can get teh case/PSU and buy a better PSU while having that one as a backup or to put in a secondary, less power hungry system.
set the window to the side and if a case that u want doesnt have one, u can always mod or buy a separate side panel with a window.
and it would be a lot easier for us if u tell us ur price range and if u will be moving it alot
ya, i have been looking at some lian-li cases, they have really cool stuff, im willing to spend whatever i need to get a nice case. :D and as for doing the window myself or getting another pannel, i think that would work to. i got a dremel.
If you want ultra high end you should probably go Lian Li or Silverstone. The new Coolermasters are really nice but they don't make good full towers now. I love my old 710.
im looking at the pc v-1200B looks pretty cool and has all the room i need for my water cooled stuff.
it would have been a lot easier for everybody if u mentioned that u water cool ur computer earlier....this limits ur search down to only size and looks because i feel that for air cooling, u should primarily choose ur case based on the cooling it provides.
pc v-1200B and all the other lian-li top-of-the-line cases are very good as to what i am told.
