Best Case for custom WC set up?
BLiTzKRiEG
I am looking for a decent case for setting up a new WC computer... I have been browsing around and was just wondering what you all thought...
I am looking for something possibly with 120mm fans as opposed to 80mm fans (more airflow with less noise).
Suggestions?
Well I have a Antec PlusView case, and Chieftec dragon. They have tons of room to mount internally, and are steel and sturdy. You can find them for cheap too.
But I also have the Apex kit in my Super Lanboy which I love however it is the thinnest lightest thing ever! Cant be rough with that one like the others ;)
But there are a TON of good cases out there, you just have to figure out what you like. And talk it over with the wallet :p
But of course the CM, and Lian Li fannys will be here soon
Pics incase you want to see:
Gigabyte 3D Aurora, or the Classic CM Stacker (I personally dont like the new one, you might though).
lian-li v1000 (or vXXXX series in general)... imo. but that's a hugely biased opinion. ;) but for reals, the perferated casing allows the whole thing to breath so well, it's really nice..
Id go with a v1200, thats my next case :D
:cool: :eek: That's my main rig.................. ;) The one I put the parts I really really like in for my own use................. :cool:
I have a Lian-Li PC75 B that has now housed the last three years of upgrades. Expensive investment, but definitely worth every penny I spent on it 3 years ago. Granted it does not have 120mm fans but you can easily Dremel that sucker to fit any need.
I cut a double 120mm rad into the top of mine and added a single 120 to the bottom front as well. Lots of room for everything. I still wish I had it :( Now I have an AMS gTower full tower (it's only the size of a Chieftech), but easily fits rads on top and in the bottom front, as long as you don't mind cutting and will accept a 120mm rad on the rear 120mm exhaust w/out cutting. Cool Technica offers this case (medium and full) in their pre-ready WC'd case.
I had airflow problems when I waterecooled my Antec SLK-3700AMB. I had to add a couple "floating" fans (not pictured) to make sure the PSU didn't get too hot. My next case will probably be one made by SuperFlower. I really like the SF-561T and the
SF-201T
http://www.directron.com/casuperflower.html
Their cases seem to be pretty good quality and not too expensive. I'll most likely cut a couple holes at the top and mount a dual rad there to maintain good airflow through the case, but that won't be till the end of next year. Right now my rig looks like this.
I am currently looking at the Antec SLK3000, since I can get that for cheap. I would probably mount the res on the top, i.e. outside of the case.
Short list:
UFO case
Lian-Li V-2xxx
Lian-Li PC-7x
Long list:
All others are problematic to one degree or another.
i've got a pile of stuff jammed into my lian li pc 60 including: lagua statuary #3 pump (pretty big) bix (took the hdd cage out and put it lying down) another heatercore at the top of my case (cut a hole out of the top of it and put mounting brackets for it inside the cdrom drive bays. and a resevoir hanging off the back.
