What is the best fan i could add to my case that gives the best air flow and is quiet?
I know this thread is about case fans but I was wondering if those enermax fans are any good for heatsinks or is 1200 RPM too slow?
Second question, if I had a heatsink that can do push/pull how exactly do I connect both the fans. Does one fan go on the cpu fan socket and the other go on a different fan header, or do both connectors get connected to some sort of adapter and then that is connected to the CPU fan header?
