Best Case Fan.
Im looking for a good case fan. I have a 9800Gx2 and it gets really hot. Right now i have the side of my case off and a fan setup next to it. I need to get rid of this ghetto setup.
I am in need of the rear case fan.
Approx 6" in size.
Id like something pretty powerful but not so noisy.
Any options????
6" eh?
Fans are measured in mm. Popular sizes for a rear exhaust is 80mm or 120mm.
What case is it? Do you not have a fan in there at all?
My guess is he is measuring the mounting holes diagonally, which would be a 120mm fan. As far as fans go, it's hard to beat the Slipstream fans, if you want to spend a bit more go for the S-Flex fans. If you want super cheap get the Yate Loon fans. If you have a controller I would suggest the 1200rpm+ versions, if not I would get something under 1000rpm, unless you don't mind noise.
