monster.under.thebed
- Aug 14, 2003
im building a new system soon and im looking for the best video card for un $200?
what do you guys suggest?
thanks
thanks
rfwinters77 said:Depends on whether you want AGP or PCI-E.
I'm assuming PCI-E, so I'll recommend the Geforce 7600GT.
That's what I'm gonna be getting since it seems to be the best bang for the
buck type card under 200 bucks.
AndoOKC1 said:I have a an X850XT @ PE speeds for sale with 1GB of ram for $200 plus shipping. It would save you money on ram and video card. X850XT is a great card pretty much the same performance as a 7600GT
http://www.hardforum.com/showthread.php?t=1043422
According to that thread, it was soldBona Fide said:I would spring on that X850XT + 1GB RAM deal. The only difference between the X850XT and the 7600GT is SM3 support, which really doesn't matter at this point in time.
