Best Card for 4 Display Options
pc1x1
I have practically given up on the 3870x2 quad dvi, they are to hard to find, and or to expensive for that they offer. I was glad to see at least the Pallit 9600GT seems to have 4 displays. And since it has a HDMI, I could go HDMI to DVI and essentially have 6 DVI ports with two 9600 GT's SLI'ed Can anyone confirm, or anyone suggest another alternative.
I'd prefer something I could use with my current computer, though I may just wait until the end of the year, and build a new one.
Yeah, i don't think you can do that in SLI. You could have the two cards in there non-bridged and it would work, but as far as I know, when you're in SLI mode you can't.
I thought SLI didn't support dual monitors. Did that get fixed?
As far as I know SLI only works with 1 monitor still.
@OP: Why not just get one great card (say, an 8800GTS 512) and then buy some second crappy card (like an 8400 or some older, used card) and get an extra two DVI outputs that way?
I don't need SLI playing games on multiple monitors, as it stands now, When I launch a game, the second monitor goes to sleep, and when I am done, It comes back.
I am looking for 6 DVI ports, so I can hook up everything, and can span my desktop while using my applications, etc. For gaming, one monitor will suffice.
I am just looking for something with 6 DVI, I may have to Tri SLI, but it seems like a waste.
Hmm not 100% sure if this will work but get 2 x PCI-E cards with 2 dvi ports on each card. Have them both installed in each PCI-E slot non sli or non xfire mode. Then, get 1 x PCI not PCI-E but PCI card with 2 x DVI ports on it and install that on one of the vanilla pci slots.
That does work, though in my current case, I only have 4 slots available. Everything else is taken, and its system crucial components, ie water cooling etc.
Not sure if this will help but...
I just built a PC from spare parts - one of the accidental features I wound up with was that the mobo I used happened to have built on video with VGA and DVI output. When I put my 8800GTS in the mobo, Windows actually notices 4 monitors I could potentially use.
If you get a mobo with built on video and VGA & DVI output, then one good card for gaming + one medium card just to run an extra couple of displays + the built in mobo connectors may get you to 6 monitors. Granted one of the mobo outputs will be VGA but if it looks the same, who cares? :)
Thats not a bad idea for HTPC, but yea, I will most likely get the real thing done, later, with Tri SLI, those 9600GTs look real tempting.
true
Thats also pretty handy.
I am looking to stay with graphic cards.
Anyone have any of the new 2x DVI and one HDMI cards. I believe I should be able to get a HDMI to DVI cable, and it should work on a monitor, anyone say if that works. Would you have 3 monitors, or would one of the DVI slots shut off etc?
