technicallyflawed?
- Aug 28, 2008
Hi,
My first post. My setup is a quad core 9450, xfx 9800 gtx, 4gb ram, antec 900 case, 24 inch dabs value monitor, psu 850 antec. It seems to me that the native res is 1920x1200 for this screen but I've been having a few probs. In some games i notice the units suffering from stutter. I've used rivatuner to use driver level overclocking and to turn the fan up to 50 percent. When I monitor fps i get ok results and had a score of 13,000 with 3dmark06. Why then am I getting slowdown. The games I got atm are company of heros/med war 2/age of conan/ddo. For company of heroes the tanks were moving terribly so I changed from dxten to high shader (i guess shader 2.0) and the improvement was huge. Therefore I believe I have some kind of dx issue with my setup. For medieval war its on shader 2.0 seems to run ok but stutters when I have a lot going on e.g being sieged by 4 armies. Age of conan is buggy but seems to run ok. Dungeons and dragons also suffers from a kind of glitching..u notice it when u see other players on screen and when I have been monitoring it it can go from over 150 fps to around 15. Is this some kind of bottlenecking? Or maybe I have to lower all settings more..I am running with some aa on but settings arent maxed.
This is not a major issue but it is frustrating cos u spend a lot of money and time and still get issues. I have read that you need 1gb for resolutions of 1920x1200. But i thought a 9800gtx should be able to handle it. I made a mistake I believe with getting a quad core @2.66 as quad core seems to be irrelevant in terms of game speed. Also I believe the 24 inch dabs value special (dgm) was kinda cheap at 200 pounds and with hindsight I think a samsung 22 inch better. However these things aside I dont want to buy a new card. But my mobo supports ati crossfire x so was thinking of 2 ati cards...however is 1 card at 1gb better then 2 512mbs in crossfire?
Am gonna be trying warhammer soon so I will see what happens when I have this up and running. Also will overclocking my cpu to 3.0ghz help or not really? I can do it with easytune 5...seems to work although my comp goes up from 20-30 to 50.c (although my gigabyte cpu cooler is at 2000 rpm and can go higher)
And last point I have been getting a resetting comp...very rarely it will go into a starting loop. This seems to have got less since I re-loaded opitimized defaults and changed voltages to auto. Also i noticed that my ram wasnt in its right coloured slots (this is different from mobo to mobo). I am wondering if the 2 problems are inter connected. However its bizarre as i can get good scores with rivatuner monitoring prog and 3dmark06.
I guess if I get frustrated I'll chuck some money at the problem hoping it will go away with a new card (was thinking of the his 3870x2 1 bg)
cheers for any suggestions/tweaks/ways to test your cards performance etc
moz
moz
