Best cabling for 6x 6pin gpu power?
rjolin01
I am trying to clean up my cabling. I current have a HAF9332 but going to upgrade to a HAFX. The main cabling i want to clean up is the 6x 6pin gpu power cords. Is there perhaps a cabling solution where both 6pins per gpu are together on same cord. it can be like a 2x 6pin to 2x pin but with the cable bundled together. I seen a nice cabling done where it almost appeared all 6x 6pins came off the same cable. Anywho just looking for ideas.
What you could do is just sleeve the PCI-E connectors in pairs of two, so the sleeving will cover both sets of wire at once. It'll be the same amount of wires, but it would probably look cleaner.
