Arctic Cooling Freezer 7 Pro -- it's 25 bucks and can do a 6400 @ 3.2ghz no problem. Probably the best bang for the buck solution out there today.
http://www.xoxide.com/arctic-cooling-freezer-7-pro.html
The AC freezer will take a conroe up to the highest stable point, without increasing vcore to more than 1.35v.
honestly I dont even know waht stock voltage is. So how big of an increase would that be at 1.35?
THERMALRIGHT ULTRA-90 775
Scythe NINJA PLUS Rev.B
So we got these 3, they all seem pretty good the XP ultra 90 does really well in the reviews I have a XP-90 now which had been good but this thing looks like it has potential. thats for sure.
http://www.legionhardware.com/list.php?category=08 some reviews. I didn't see a review on the ninja though
i'm currently using my ultra-90 with a pentium d 915, although i am planning on getting an e4300 this week. anyways, my ultra-90 keeps my overclocked 915d at 36c idle and under 50c load. keep in mind this is a presler core which typically runs hotter than an allendale or conroe core. as to whether it can take a 120mm fan, with some creativity i don't see why. if your familiar with thermalright heatsinks, this one uses clips to secure the fan as well.Anyone own the Ultra90 and use a C2D? Ive been wondering if these would be able to have an 120mm fan attaached to them somehow?(I can use zipties if I have to)
Ive been somewhat shopping around for a C2D heatsink as well. Im definitely not one of those people that buy a Tuniq tower for $50+![]()
I have an HR-01 right now, which I believe would be great but.....Its for K8 right now and Id need that damn bolt through kit which NOBODY sells.
Ive been debating between the Ultra90 or maybe AC.
Doesnt the Ultra90 perform better than the AC freezer 7? I would think it does.
