best blue dye?
Hey I recently put blue and green dye into my watercooling systems .. I have 2 .. 1 in each .. the green came out great .. but the blue is so faded barely glows. Anyone had good experience with a blue dye in particular?
I've had the same experience with blue dye. It doesn't seem to glow worth a sh*t.
Doesn't that suck .. I've seen some peoples setup and the blue is was really bright and I say to myself , damnit I want blue like that!
Thats way better then what I got. What else did you put in your water? Waterwetter? Anti alge ? About how much of the FrozenCPU stuff did you use? How much water is in ur setup?
ALOT OF QuESTIONS HUH ? :D :D
I stuck the waterchill anti algea stuff in there, Innovatek innovaProtect Fluid which actually raises your temps so I wont be using this again on my next set up which ill be setting up soon, I'm gonna use waterwetter. That frozen CPU blue dye stuff is crazy i used like 4 drops, one bottle will last forever. And I have no idea how much water I'm using:D
yea its powerfull stuff, if you put the bottle next to a black likght it actually looks green. Like mint green, which could look cool to. If you start to put to much, like 10 drops, the blue will start to turn this greenish color.
my bottle of green dye is the tracerline dye the bottle wont even glow next to a black light its that concentrated
