Best blow-through HSF?
Decker87
Hi. I am looking for a heatsink/fan that is designed to blow from front of the case to back. I have a socket A proc/mobo if that helps. I am currently looking at the Scythe FCS-50, and maybe artic cooling products.
scythe ninja is the best i think, but im not sure if it works w/ socket A. go look it up :)
the new thermalright hr-01 is just as good as the ninja i think, but im also not sure if it works w/ socket A. i dont really pay attention to these things when im looking at heatsinks :p
the ninja doesn't come with a fan, not sure if the thermalright does but even if it does, you'd probably want to get an oem heatsink and pair it up with a good fan.
Anyone else? I can't afford to put a big ninja in my case, both space-wise and as far as money is concerned. Hopefully I can find something under 40 and preferably under $30.
*edit* nvm didnt check compatibility. a lot of these new heatsinks dont work w/ socket A :(
