Feb 24, 2004 #1 R rayg Limp Gawd Joined Jan 29, 2004 Messages 505 what is the best heatsink/fan for the 2500+, i plan on overclocking it to 3200+. I dont really want to spen more than $30 for it.
Feb 24, 2004 #2 D doh-nut Supreme [H]ardness Joined Dec 7, 2000 Messages 5,409 thermalright sp-97 + 92mm tornado. but itll be over $50 for that set up.
Feb 24, 2004 #3 L LyL18 Limp Gawd Joined Feb 4, 2004 Messages 468 mmm Speeze Whisperrock! $9.99. Booyah. Works very decent too
Feb 24, 2004 #4 A afong Limp Gawd Joined Nov 3, 2003 Messages 145 Vantec AeroFlow ($24.99 @ new egg) cools very well and is pretty quiet. The ALX-800 also does a very good job, but it might put you just over the $30, depending if you find one that comes with the Delta or if you buy your own fan.
Feb 24, 2004 #5 N NateCooke n00b Joined Feb 19, 2004 Messages 20 Zalman CNPS7000-AlCu is cheap, silent, and effecient. Keeps my 2500 around 40C under heavy load at 1.8v. It's a monster though, and doesn't fit on quite a few mobos. Check http://www.zalman.co.kr/usa/product/cnps7000a-462_motherboard_list_eng.html.
Feb 24, 2004 #6 D darktiger [H]ard|DCer of the Month - April 2007 Joined Apr 10, 2003 Messages 11,819 Vantec AeroFlow
Feb 24, 2004 #7 S ST|FFY [H]ard|Gawd Joined Dec 16, 2003 Messages 1,650 i also recommend the Zalman, if ur mobo fits...then get it!!
Feb 24, 2004 #8 K kronchev [H]F Junkie Joined Feb 23, 2001 Messages 12,051 ill sell you a Zalman 7000 AlCu for $25 shipped it is the best cheap heatsink combo
