The18thLetter
- Dec 27, 2004
Alright, I'm in the market for a new widescreen LCD monitor thanks to my tax returns, and I'm wondering what's the best bang for the buck?
I'm not looking to spend more than $300 and I don't need a humungous screen, either.
I currently have a 15" Dell LCD Monitor, and I'm quite content with it, honestly. My only complaint is that the maximum resolution is 1024x768
. I'm looking for a jump to 17 to 20", depending on what I can get for the price.
What caught my eye, though, is:
http://www.newegg.com/Product/Product.asp?Item=N82E16824009073
Problem with this one, though, is that it only supports an analog RGB connection. No DVI here.
and
http://www.newegg.com/Product/Product.asp?Item=N82E16824116373
Yay DVI! lol but then this one has speakers on the bottom that I really, really don't need, won't use, and will quite possibly get in the way of my central speaker (I currently have my speaker set just under my monitor, and am aiming to have the same setup with my new monitor)...
So... what's the verdict?
Which of these two is the better choice for the $$$ or if you have a better suggestion, what is it?
Thanks!!
and
Thanks!!
