Best audio mATX motheboard?
Gn0m4
is there any mATX (audio integrated) that will could compete with a dedicated audio board (SoundBlaster xFi)?
Thanks !
Thanks !
If you're a true audiophile then no built in solution will suffice, unless there is some board out there catering to media minded people you're better off going with a dedicated card.
That being said, the last audio card I purchased was an ISA slot audio card for $16 back in the early 90s and I've had no issues listening to my songs or watching movies on the newer built in offerings with any of my motherboards from any manufacturer.
I'm not sure if just a marketing hype from Asus. But their high end micro ATX motherboard the ASUS Maximus V Gene has "SupremeFX III" sound
The idea is to separate the sound from the rest of the motherboard. Signal to noise ratio is rated at 110dB.
The ASUS MVG does have "SupremeFX III" sound...but it's really just a Realtek codec with sound blaster drivers or some nonsense. It does have the red LED "moat" to separate the chip from the rest of the board, along with an aluminum cover over the chip to keep out EMI.
To me, it sounds no better or worse than most on board chips. If I hadn't read about what it was, I never would have noticed.
Yup. The "Supreme XFI" on the LGA1155 Genes is merely your run-of-the-mill Realtek ALC DAC with a Creative supplied Windows Media Player plugin.
Seriously. DAC inside the PC sounds so bad. The same sound card ime produces much better sound if you convert to analog outside of the giant EMI mess that is the inside of a PC.
Your cellphone generates more EMI than your PC does. The internal noise inside a case is way overblown IMHO. Besides, a quality PSU provides FAR cleaner power than your wall does if your external DAC/Amp is not bus powered.
there is this stuff called USB DAC
what they do is make the sound quality of your pc sound better.
something like the FiiO E10 is regarded as a very good choice.
you could usually get those for $70
I just always have a receiver or sound processor (aka receiver without the amplifier function) that I connect my computer to via SPDIF. Sound quality is always better and I can control everything that comes out through the receiver instead of fiddling with soundcard software that is generally subpar.
If you can find one, the MSI Media Live Diva had and excellent audio system. The only problem with it was that it would only except the original AM2 and Phenom I processors. There was a 5.1 channel amp or 7.1 channel pre amp versions.
Great audio reviews about this mb. What about rest of specs?
Which specs are you concerned about? Heres a decent review from vortez if interested.
Audio wise it only does 5.1 but it does come with a seperate creative audio chip CA0132 with emi shielding. Also it comes with a built in headphone amp if that is of interest to you.
I´ll go to connect a headphone for gaming (probably Creative internal Headphone connector to attach to case´s jack connector, hope no add noise) and Creative Megaworks for music (rear pannel connectors).
Do you think USB Dacs or dedicated audio cards are better for gaming with headphones?
I have never owned a soundcard so I cannot comment on the your question. But, if you are going to use headphones(which is what I do) I use the rear panel headphone jack on my sniper m3 which comes with headphone amp.
Again I have never used a sound card but for gaming and occasionally listening to music it sounds damn good.
Thanks !
I tought Creative headphone audio amplifier was only internal connector, not rear panel jack. Looks great, I can keep all my devices connected at same time.
Do you think has enough power to move a big headphones?
I use the steelseries siberia which have 50mm drivers and it is pretty loud. I keep my sound level at 15% for games and 20% for music anything above that is too loud.
My ASUS MVG is advertised as having really good onboard. I can't attest to it though as I use a titanium xfi HD. I guess that makes my post semi useless. :/
Those often do add noise. You can check by plugging in headphones and listen to them with nothing playing. You may hear a bit of buzzing that the internal cabling picks up. Also when doing that, move the mouse to see if that adds buzzing. And yes, I've heard this on front panel ports plugged into X-Fi card headers too, not just onboard audio.
Yea well, Beat Audio headphones are advertised as really good too. ;)
