Best ATX Case for <$75
Table
Just need a simple but elegant looking case for less then then 75 bucks (the cheaper the better) PSU not included, and no bright LED light bs.
thanks
i'd go for the first one out of the above two, but you'll need another 120 mm fan, because it only has one built into it.
Either the Centurion 5 or 532(slightly more expensive, front 120mm intake, but more restrictive HD cage). Best budget cases out there.
for the advice
the Liam Li is tempting as ive always heard good things
TBH, I'd jump on one of the P180/B deals that end up being $80 shipped or similar. ;)
But all of the above mentioned cases are quite slick looking as well.
which deals are those :( i want to buy that case but the only time i heard of that deal was at frys but i dont have a frys here in FL
any ideas?
any ideas?
I believe in the [H]otDeals forums, there was one @ Bestbuy, but that's currently backordered.
Just gotta be patient really. They do pop up rather often. :)
thanks! i will keep an eye out for it ;D
sowingseason said:
aspire x-sonic ftw., maybe you can find a antec super lanboy under $75. those r nice too
The "simple but elegant looking" requirement sorta kills if for those two.
dont' forget to pay with paypal @ newegg and get free shipping when you use the code paypalfree (up to 20$ off, standard 3day ups only tho)
absolutely perfect for case purchases
i love cm cases, go with any of those listed that is most aesthetically pleaseing to YOU
i have the centurion 5 btw, love it :)
p180's are hot shit too, i might get one because they are, imo, the swankest cases around
