Best Airpurifier?
Chadwick
I have been researching air purifiers for the past week and looking for one primarily to reduce allergies, sinus infections and dust. I've narrowed it down to three units and looking for any possible input on the units I've picked or maybe one's I browsed right over.
The Sharp Plasmacluster FPP60CX $300
Rabbit Air BioGS model 421A
$330
Blueair 402 Air Purification System $391
My budget is right around the 300ish range.
Thanks again for any input! I'm hoping this is alright in the General Hardware section....
$330
For smells and ultra fine allergens, HEPA will not do much. You'll need to make sure it has both HEPA and Carbon filtration together. HEPA will capture the larger particles, and the Carbon will capture the smaller particles along with odors.
One such filter is the Austin Air model. (The large one) I'm sure there's plenty more with Carbon filters, though. Search around for the best prices.
I bought a $50 'heppa-like' air purifier from wal-mart and have been really happy with it. It does help to cut down on oders and after 2 days you walk into the room and it's noticable. The filter is heppa-like and charcoal The larger dust particles are gone but very fine ones are still there.
I would recommend the Sharp Plasmacluster series, I have 2 and have bought a few for family members.
Just picked up the Sharp Plasmacluster FPP60CX from Amazon for $271. Thanks for the input guys. :)
I'll have to write up a review in a few weeks. Hopefully the sinus issues and dusting needs will be eliminated.
