Best airflow setup..
JAW
Whats the best airflow setup to have? Currently here's what I have.
2 80mm exhaust fans in the rear
1 80mm intake fan in the front
1 80mm side window intake fan
PSU exhaust fan
well, theoreticly it would be best if you had all your case fans as intake and then line the top of the case with exost fans(cool air comes in lower i the case, goes over gpu, chipset, and cpu, then out the top. thats how id do it. but you dont realy have the roof fan option, so id say wat you have now is good, maby change the window fan, but thats it
PSU exhaust fan
120mm intake
120mm exhaust...
80mm exhaust top
80mm side intake
or mine
2 92mm intake
2 92mm exhause
180mm gpu blower
1 80mm cpu blower(both of these are in the side of the case blowing directly on it)
2x 80mm blow holes in the top
