I am working out the best route for my case fans so I don't sacrifice airflow after my w/c is installed. I have a PC-7B and the rad (double 120mm) will be mounted inside the top of the case. I was thinking of having the 2 120mm on the rad blowing air outside the case and then having a third 120mm blowing out the rear. I also have a Enermax Liberty with yet another 120mm. What do you guys think am I on the right track or is there a better idea. Thanks
