Best Aircooling
CrazyBeaner
right now i have a TT BT, W/TT Thunderblade, and my temps are as followed 31C idle, 45C load, and im @ 2.7ghz @ stock V, i want to oc more meaning 3.0-3.5ghz granted i know i can, i oced to 3.2ghz @ 1.6V and i was idleing @ 36C and load was around 49-52C, so is there any cooler out there being from tec or any better than can drop my temps maybe 5-10C ? and will a single 120 Rad h2o Swifttec kit be any better than top of the line aircooling or tec?
thankz
with a single 120 you'll be pushing it. You'll have to REALLY crank up the fan. It will be cooler, yeah, but not worth it considering the noise.
also, your temps are great. good luck dropping them 10c....
A single "kit" watercooling setup will perform about the same as your TT. Get petras "light" kit for something with some oomph to it.
The Tuniq tower would be a bit better, but not by much... 3-5'c tops.
