Best aircooling solution (Case fans etc..)?
madgun
I have a Lian Li A-05 which has an unusual airflow. The air is taken from the back of the case and exhausted from the front, I want to use really fast and at the same time quiet fans that could draw a lot of air in and discharge hot air quickly. What would be best way to go?
PS: My casing lies under the desk so the surrounding airflow is somewhat restricted anyways.
120mm fan would be your best bet. They tend to move alot of air and can be pretty quiet.
Oh and for your case airflow, you can always flip the fans so it sucks from the front and blows from the back.
yea currently I have two Lian-li 120mm's, which fans should I get that would be relatively quiet and at the same time draw a lot of air in.
IMO, I love my S-flex fans. They are expensive, but they are well worth it.
I have a few of the Enermax Enlobal 120's I've been quite happy with, and they are quiet.
