CoolD said:What heatsink would you guys recommend throwing on the DFI nf4 Ultra-D? Are there any issues with space with a bigger hsf like the zalman 7700's? How's the xp-90 fit?
Swiftech MCX6400-V http://www2.newegg.com/Product/Product.asp?Item=N82E16835108037CoolD said:What heatsink would you guys recommend throwing on the DFI nf4 Ultra-D?
The Swiftech box says this is a "low noise" heatsink. Can it really be "low noise" without any moving parts?Renegade87 said:
Um, the MCX6400-V ships without a fan so you have to add your own. But the MCX64-V has an included 80x25mm Delta fan rated @28db, 2700RPM, 31.4CFM. It's supposedly pretty quiet and tested at only about 1c higher temps than the MCX6400-V with the same fan.axiom said:The Swiftech box says this is a "low noise" heatsink. Can it really be "low noise" without any moving parts?
