I hate the stock Intel HSF. Long story short, what's the best 92mm HSF for a Q6600? I don't think I can fit anything over 92mm since my Enermax Uber Chakra has that ginormous 250mm fan protruding a few centimeters into the case right over the CPU
I'm using the TR Ultima-90 with my E8400, upgrading to a Q6600 tomorrow.
So far I've been fairly happy with this HS, using a Scythe 92mm PWM fan. Sitting at 52/52 (oc'd @ 3.8ghtz, folding 24/7) as reported by RealTemp. It should be noted that my cheap Rosewill case has almost no air in take in front of the CPU. I dropped the temps on my existing Q6600 by about 10 degree's by removing the unused 5 1/4 bay covers. That one is using the Zalman 9700nt (oc'd @ 3.0ghtz, all cores < 50 degrees folding 24/7).
