best 80-250gB external harddrive?
i was thinking about getting a Maxtor, but are there any brands out there that are better and lighter on the $$$?
im sure the answer was posted in another thread but i didnt see that thread so could i get some feedback
-thanks
easy answer. get a 3.5" external USB2 enclosure from a place like www.computergeeks.com for a PATA hard drive (make sure it supports drive the size you want aka over 120GB) and then go buy a good WD drive from www.newegg.com or something. there saved a ton of money.
