Best $70 budget card.
vitriol
Yeah, I don't mean to a stupid redundant n00b with my questions here... but, I have about $70 to burn on upgrading my friends old ass GeForce2 :rolleyes: MX200 to something a tad more... Modern?
I checked the recommended upgrade guide but am asking here out of a hunch that guide may be -slightly- dated. :confused:
:eek: So any accurate suggestions would be mucho appreciated! Links to newegg would be best if they weren't to out-of-stock cards :D
Thanks!
boy.. thats a tough one.
id try ebay and a ati 9600 256 mb card.
pricewatch.com has them for 77 bucks.
newegg refurbs - you should be able to get a 9600pro/xt, 5700 or maybe a 6600 (non gt.)
Check out the forsale forums here as well, some good deals can be found (also anandtech for sale forum). Ebay can be ok, but watch out for the shipping cost.
Well damn. That nvidia card is $9 more expensive and only supports DX8? I'm such a n00b I don't even know the benefits of a card supporting DX9 where another card doesn't. :confused:
I assume the more expensive card is better, and I'll buy it. Just wondering if the DX8 is a setback when the other is cheaper and has DX9.
uh...DX8 will reduce your amount of visual effects and maybe even performance. Get the DX9 card (which the radeon 9600 and above should be faster than the 4400ti)
There's no reason at all you should settle with anything less than a 9600 Pro. Simple facts are this: The new engines will not support cards that Geforce 4 or older (take the BF2 engine, it wont accept Geforce 4s). Then also the Geforce FX series of cards were crap.
So this leaves you with maybe getting a 9600 Pro somewhere, or possibly a 6600(are they this cheap though).
So fromthese, the 9600pro is hands-down what I should get?
And what the hell is 'atlantis' supposed to mean for a radeon? I don't see a thing different between the cards except price.
The 9600 pro's have OpenGL up to 1.5, the 9600 has OpenGL of 2.0.. wtf?
Probably a typo. All of those cards are a good choice, I'd just go for the 128MB one as it's slightly cheaper and the 256MB will be useless anyway.
EDIT: Oh wait, that 9550 has a fan. Might try going with that one for a chance at overclocking the thing.
And he could get a 9600 Pro and still have great OCing. Those things were not unknown to get a 100mhz OC on core.
i believe the sapphire advantage 9600 pro has a lower memory clock than regular 9600 pro's (should be 600mhz)
