best 680i board?
himmy
Looking to upgrade my 6300 when the quads are lowered in price and wondering what is the best sli board for overclocking?
thanks in advance.
Search would be your best friend.
There are about a zillion threads on the 680i motherboards in here.
Before you buy a Quad core CPU, you should research whether or not its best suited for your needs and if the Quad you plan on buying overclocks well. I have not seen any convincing data that the Quads OC that well.
Right now I cannot justify a quad for games that I like. There is no advantage over dual core at all and rarely any advantage over a good single core.(at this point in time)
I've used them all and I've got to say that the EVGA 680i SLI (122-CK-NF68-T1/A1) are hands down the best 680i SLI boards out there. The quad's overclock fine, they just don't overclock as well as the dual core CPUs do. Honestly if you have a good overclock on your E6300 I wouldn't bother replacing it unless you know for a fact that you'll be running applications that take advantage of the extra cores.
i personally would go for the evga, even though i have a striker
I own the Striker Extreme as well, and you can tell by my sig which one I am using. That should clue you in as to which is my favorite. I've also used the P5N32-E SLI and the N680SLI-DQ6 from Gigabyte and though it's a good board, the EVGA overclocked better and has a better overall thermal solution in my opinion. The P5N32-E SLI has a pretty poor chipset cooler, but they seem to be less troublesome than the Striker Extreme they are based off of.
i went up a few weeks ago to 1102 i believe, works great for me.
That one has been out for awhile then. That's what's on mine. I didn't use it for very long, in my case I think the 1102 was worse than 0505 or whatever old ass BIOS I had on there. I pulled my Striker and replaced it with the EVGA 680i SLI and I havne't looked back.
I've been using the EVGA 680i since mid-April and love it (along with Vista) it's the most stable machine I have built.
Ok, I'll chime in.
I have the notorious ASUS P5N32-E SLI board, bios 1002, dual 8800 GTX and I havent had a single problem with this board.
Now, I was using the release bios 0202 since November and had absolutely no problems either. Thought I'd up the bios to make some use out of ntune, worst mistake I could have made.
I loaded up ntune thinking I could ramp up my fans on the 8800s.
First, the new driver set doesnt recognize the fan speed controls (158.22)
Second,the addition of ntune caused all sorts of issues, random crashes,games freezing, you name it. I thought I'd really fubar'd my board.
So, I reloaded the bios,and reformatted my HD.....things are back to normal and the computer is running as smooth as butter.
I'm not sure if it was the BIOS version, ntune or both......I have to say, I think it was ntune,since I reloaded the same bios and got rid of ntune and all else remained the same.
I use Rivatuner now.:D
Oh yeah, this board is Quad capable and has OC'd my e6700 beautifully. When I bought it, it was only 165 bucks, I think it's 200 now.
although, now i have the latest bios my striker is rock solid :)
I beg to differ on this. The only thing holding me back on ditching my striker is sloth, I can't be bothered to do another rebuild.
I have evga envy as it's better quality, better oc, more stable... just doesn't look as bling and lacks some features.
I've built enough evga builds for friends to get a feel for it.
For a while I did justify the striker simply because I had one, and it's hard to admit you paid that much for a product, which frankly, is inferior to most others apart from asthetics.
I've also had the Striker and EVGA A1 revision. I struggled with my Striker for months convinced it was something I was doing that was making the board act like a spoilt child. I eventually bit the bullet, bought the EVGA and haven't had a single problem since. To me, the EVGA seems far more stable and feels like it runs better over the Striker.
The Striker seems to have problems with fast DDR2 modules where-as the EVGA doesn't struggle so much. Also, the overclocking potential the EVGA has with my QX6700 over the Striker makes it hands down a better candidate.
I should have bought the EVGA from the start.
am too using the EVGA board. haven't updated the BIOS since December, but the rig's working flawlessly. and why fix it, if it ain't broken? ;)
running a QX6800 :D (no.. i'm not rich.. it was free :D) @ stock. i really have no need to OC it. the 2.93 on 4 cores is enough for what i do.
Having a 680i board, a core2, and not OC'ing it is a shame;)
i'll OC it when i need it :D right now, all i do is internet browsing. so really.. i see no benefit from running the chip few mhz faster. ;) other then bragging rights :cool:
I prefer the ASUS P5N32-E SLI seeing as I own it and get great overclocks... It has the same major specs of the Striker but without all the extra crap to mess things up. I have used the EVGA boards before and was not too impressed. I had issues with stability with them, but I think I kept using the earlier revisions.
Using an eVGA 680i board since May and have had no problems whatsoever. I would totally recommend this board.
The ones that came flashed with BIOS P21 or P22 were crap. Boards that came with BIOS P23 through P26 have been perfectly fine. I haven't seen any that have shipped with anything newer than P26 so I can't comment on that.
I have a friend who has a P5N32-E SLI in his machine and it's had some occasional hiccups stability wise, also when he flashed the system BIOS to fix the sound issue that the 680i boards used to suffer from the damn flash failed. (He was using ASUS' shitty Windows BIOS update utility.) He had to order a new BIOS chip from ASUS and have me install it. ASUS wouldn't help him out either. It cost him $30 to get the BIOS chips overnighted to him. He could have switched it for $5 plus shipping and handling if he wanted to pay for them to reflash the chip, but he decided against it. He wanted faster results, but in the end I learned a valuable lesson, ASUS' Windows BIOS flashing utility blows goats. In any case I had suffered the same exact situation as my friend about 2 or 3 months prior with my Striker Extreme. So based on that and some of the other problems I've had with the board as well as some of the issues I read about on various forums, I can't in good conscience recommend the ASUS P5N32-E SLI or Striker Extreme. I don't even recommend the P5N32-E SLI Plus which is supposedly a good board. I know it's based on the design of the P5N32-E SLI and the Striker Extreme and because of that I am leary of it. So I just recommend the EVGA boards instead. They are cheaper and tend to overclock better in my experience.
The N680SLI-DQ6 is an ok board, but it doesn't OC as well as the EVGA boards do and the feature set and chipset cooling solution are kind of goofy. Plus I hate the BIOS because of that cntrl-F1 bullshit I keep hammering them about in each of the Gigabyte reviews I've done. The board's good but there is no reason to recommend it over the EVGA so I don't.
Don't get me wrong either, all is not perfect with the EVGA boards either. I have assembled probably 10 or so systems using the EVGA 680i SLI boards. Some of those are machines I own. I have had two boards (122-CK-NF68-AR) that pre-dated BIOS P23 and they were both crap. SATA corruption issues, sound issues and various stability problems. I have another EVGA 680i SLI board (122-CK-NF68-AR) that I did use in my main gaming rig until I went quad core and that's now in my girlfriends gaming rig. It's been flawless and rock solid all the way. The next board I purchased was a EVGA 680i SLI (122-CK-NF68-A1) which I accidentally damaged while installing a water block. That's my fault and not EVGA's so I don't blame them for that. I then purchased another EVGA 680i SLI (122-CK-NF68-A1) and it was DOA. I couldn't even get POST codes out of it. The board gave indication of power but was totally dead. So I took that back and grabbed another (122-CK-NF68-A1) and I have had it for about three weeks or so. Two nights ago my system locked up on me and I was forced to restart it. Upon restarting it the system wouldn't POST and it gave me a no memory beep and hung on the code C1. (Memory initialization code) and wouldn't go any further. I tried different sets of memory, and cleared CMOS. No go. Finally I tried the old memory stick in the fourth slot trick that works so well on the Striker Extreme for solving various no POST issues and the system came to life. I went in and set everything to stock and restarted it to make sure it would work. Everything came up. (Still with one module installed.) I returned the module to slot 1 and then installed the second DIMM where it belonged. No POST. So I ended up trying both chips in the black slots (second bank) and that didn't work either. Finally I tried both modules seperately in each slot and found out slot one is bad and the system won't do dual channel anymore. So last night I pulled the board for replacement. Of course we all know about the stupid resistors on the back of the CPU socket area of the board that cause various installation problems with alot of cooling hardware. This is really the boards largest design flaw.
So while the EVGA 680i SLI isn't a perfect board, I've found nothing better for SLI compatibility. I generally recommend them for anyone wanting SLI without hesitation chalking up some of the more negative experiences to back luck on my part or mistakes I made such as the time I broke a board accidentally. For anyone not looking for SLI support I steer them to Intel chipset based boards or a different nForce 600 series solution like the 650i Ultra which I've only had fantastic experiences with in the form of the EVGA 650i Ultra boards. So as I said before the EVGA board isn't perfect but until something better comes along for SLI compatibility it's the best choice right now in my opinion.
