chrisf6969 said:FOR THE 100th freaking TIME, current videocards (brandwise) ARE ALL the same!!!
the only thing slightly different is the bundle and warranty
quality is good on all of them, they all use reference designed PCB's, they all overclock with in the same margin (varies)
The difference in overclocking has to do with variations (luck) in the GPU core and memory chips, neither of which is made by any of the manufacturers.
They all use the same exact core, same PCB layout, same exact memory, same BIOS (thats why you can flash any brand bios), most use the same HSF, but none of the non-reference coolers have really stood out as better, in fact many argue BFG's is worse b/c of its one piece design.
Videocards are much different from motherboards where brands, PCB's, BIOS's are all different and perform differently.
Flip a coin, find the cheapest, brand doesnt really matter on a videocard
( MY POST SHOULD BE A STICKY SO EVERYONE STOPS ASKING THE SAME SILLY QUESTION)![]()
