Best 6800 Ultra Cooler?
makshim said:
Stock... I believe...
u wish !
Zalman VGA cooler is best.It cools both GPU and memory of the card.
It can be quiet.
if u want more airflow, it can be abit loud.
U can change setting for quiet or loud. louder = more air flow.
Phase :) Well, it's not water, right? I guess that you can find things that are better than stock. You could make your own and slap a 92mm fan onto it. Hehe.
The stock cooler is remarkably good for air cooling. If your case has bad airflow then an NV Silencer 5 would help, but you have to hack up the backplate, etc....I personally bought the Ultra since it had faster clocks and a big ass heatsink :) If it had the GT cooler, I probably woulda got a GT, vmodded it, and changed the cooler. I just figured the Ultra was easier. :)
Yeah those temps are really good man, I wouldn't worry about swapping out a different cooler....GPU's take alot more heat than CPUs....6800 GT's hit 80C+.
viperdv2k4 said:
I have good airflow and 2 fans blowing right onto the hs of the gpu. 51 C idle, and around 57 full load.
Hell those are good temps. My dual 6800 Ultras idle at 60C and get up into the 80's while gaming.
Yeah, I just installed my Zalman over the weekend. What a difference. Cools better than stock and is much quieter. You won't be disappointed.
