Best 500GB eSATA solution?
dejacky
I want a 500GB external eSATA (Express Card + external hard drive) storage solution to use with my Dell Latitude D820 notebook. Which is the best bang/buck for my requirements in order of priority?:
1. Quiet (as silent as possible)
2. Reliable
3. Speed (as fast as possible especially for video + audio editing)
4. looks (i don't care how it looks)
Thanks in advance :).
btw,
which 2-drive capacity hd enclosre would recommend that is as Quiet as possilbe, but can fit two of these hard drives and be used in RAID 0 configuration?
i really like the Iomega Drives, There backup software is rock solid and 1 button to use
dejacky said:
btw,
While I think that
External drive + RAID-0 = recipe for disaster
I recommend you take a look around here:
http://www.sataenclosure.com/
http://www.satagear.com/
they have a lot of 'neat' things, though are a bit pricey.
www.servercase.com may have some too, I am not sure.
since i have 2GB of ddr2 667mhz memory, perhaps raid 0 is not worth the speed considering it's more vulnerable to failure. What do you all think of the Seagate Baracuda ST3750640AS 750GB hard drives? I was considering maybe just getting this and using it in a passive SINGLE eSata enclosure w/ my Dell Latitude laptop. thanks!
Can someone pls clear up these SATA standards for me? I basically want the fastest External serial ata hard drive (paired w/ the best Express Card sata card for Dell latitude notebook computer). What is the difference between eSATA & SATA II? What is the best for my purposes of recording/editing high definition audio and video in real time to an external hard drive?
http://www.hardforum.com/showthread.php?t=921565
DougLite said:
Furthermore, none of these new features will improve the mechanical performance of a hard drive. You will see the same transfer rates and seek times with a 3gbps NCQ drive as the same drive running @ 1.5gbps without NCQ.
Provided you stay SATA throughout the path from your ntoebook to the drive, the enclosure and card you choose should not affect performance much if at all.
