Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Has anyone else tried The Plug from Koss? They are the poor man's Etymotics, even the poor man's Shures. They are of the same ear-canal design, with earplugs and all. I got mine for $20 a while ago, and after replacing the stock earplugs, the sound quality is awesome for the price. I've moved on since then, but they are worth looking into if you can't adjust that budget.
