sakurakana1003
- Nov 22, 2004
Bought the Arctic Cooling ATi Silencer 4 VGA cooler and Arctic Cooling CPU Thermalpaste from newegg for 50 bucks, man this is about the best "upgrade" I've done in a while. My X800 XT PE's idle temp dropped about 10 degrees from 45 to 35, but load temp dropped a whopping 20 degrees Celsius!!! Load temp used to be 75 degrees but now is at 54 degrees! CPU temps also dropped about 15 degrees with the new thermalpaste plus the fact that the VGA cooler gets rid of the hot air through the exhaust vent towards the back of the case. I recommend anyone that has a decent video card to pick up a cooler from this company, they are really making some amazing things.
Drawback: it's quite large so make sure that your motherboard can accomendate it.
I have the Zalman cooler for CPU btw, had it since the very beginning so most of the paste wore off after repeated dust cleaning sessions.
EDIT: I think I'm gonna put the thought of upgrading on hold until next generation after this little "mod".
