Dolph said:Hey, i have a Sound Blaster Audigy LS 24bit, and the Logitech Z-640's. Does anyone know what the perfect Speaker Positioning for the gamer? If i need stands then so be it.![]()
Dolph said:Thanks for the tip. what do you mean environment? Ive heard that the rear speakers should be beside you putting the sound right beside your ears, and then others have it like a square with you in the middle.
