Best 27" non 1920x1080
Haidden
I just bought the BENQ XL2420T and after calibrating it, its not a bad monitor but I just keep thinking about a 27" monitor instead and going outside the 1920x1080.
Gaming is the most importing, low input lag, etc. Any suggestions, none of the korean monitors, prefer to have good warranty etc.
$700 or less would be best.
120hz or better
Samsung s27a850d's went down in price probs because the 27b970d is out. I usually see them cheaper than Dell and obviously Apple.
I'm trying my luck going Gangnam Style. Should be joining the QHD club today or tomorrow.
Looking for 120hz or better, great for gaming as I have one of the better 24" right now for gaming XL2420T, but if I can find an equivalent 27" (non 1920x1080) I will return it.
The Samsung 27b970d looks pretty nice but input lag seems bad
I'm confused. Do you want a 120hz monitor with a resolution greater than 1080 that isn't a Korean ips?
Ah ok, Yeah I was/am looking for a 27" that does 2560 x 1440 at 120hz+.
...At $700? Give it at least a year. If you can find one, some Shimians can do 130hz at 1440p. Though they are Korean.
Also, what are you planning on running at 120hz 1440p?
If you want a 1440P Monitor that does 120Hz you have two options: Overlord Tempest or Yamasaki Catleap. Both come in OC versions. I own a Tempest OC and the performs amazingly.
