This has been asked a million times. You should do a search in this forum.
Most people will say the 3007WFP because of low input lag.
Others will Say 3008WFP because it is hard to notice the input lag difference and you get the benefit of more inputs as well as a sleeker design (arguably).
Do a search for Input Lag Wars on google - the avsforum guys have a great thread about using some of the better LED TVs as displays and have some really nice info all in one place there. The Panasonic they highlight is one of the better screens from what I can tell and it's about $700ish, +/- $150. I had no idea about TV performance before I saw a link to their forum in this section so just thought I'd share.
Lowest Input lag of any LCD Display, not just 30 inch. Why? It relies on the GPU to do any/all pre and post processing for the monitor. Most monitors have some sort of hardware that will automatically scale what is displayed just in case your OS or GPU is off a bit. This additional processing causes input lag.
The LP3065 has been evaluated against top of the line CRT displays because of the absense of Input Lag. Any comparative evaluations including the 3065 show it to be the standard, untouchable by any other model.
I'll put it another way... This monitor has been on the market since early 2006 and still goes for $1200+ on Newegg for a reason.
I have had mine for over a year and a half now and couldn't be happier. Much better than the POS Dell 24' I had before.
