BillR said:Of all the ED plasmas Panasonic does make one of the best cant argue that at all. Id still consider and HD set though, as HD gets better you will probably not regret the step up in the end. Nothing worse then buying something only to have that thought 6 months later damn, I wish I woulda![]()
ScHpAnKy said:know of any 42" HDs for under 2500?
darktiger said:
JackieO said:ScHpAnKy, are you using this as a computer monitor? If so, you need to go with an HDTV set. EDTV is awesome for SDTV, HDTV, and DVDs however you will notice the lack of resolution when using it as a computer monitor.
If you're not going to use this as an HTPC monitor, EDTV is wonderful (the Panasonic 6UY or 7UY series is the way to go). If you are, you're going to need to add to your budget and get an HDTV or grab an LCD.
