Best 24" Options
Looking to do a dual monitor setup. It will mostly be fore work: programming, system administration, some graphics/web site stuff. Also a little but of gaming probably. Prefer something 1920x1200, but might do 1920x1080 depending on price. Would also prefer adjustable height and portrait rotation.
I was thinking Dell U2410, in that case I'll wait to find refurbed. Or maybe I can find Gateway FHD2400 to pair with the one I have, but that seems less than likely. Any other options?
U2410 sounds good. As an alternative: HP ZR24W (it's a bit cheaper, but has less input options and isn't wide gamut).
I like that HP. Thank's I'll definitely consider it. Anyone have a 1080p 24 inch with height and rotation they could suggest as a cheaper alternative?
Generally the 1080p screens are 23" at around that size. Dell U2311H...
The Samsung 2333T (*VA screen) is a bargain at the price it goes for, although it's supposed to ghost a bit when gaming on it.. but it's really really cheap.
The U2410 is worthless now when we have the Asus Pa246q and the HP ZR24W to pick from, or get 2x U2311H/EA232/ML239H/IPS236Vs for around the same price if not less.
Luckily another FHD2400 went up on ebay and I grabbed it. In fact another one is up there now as well. I was considering grabbing it and maybe doing an eyefinity setup. I know I'd need an active DP>DVI adapter to do 3 over DVI, but I've also heard there may be issues with that. Anyone have any experience with a similar setup?
