Best 24" for gaming
redrum_237
Hi guys! Which 24" TFT is best for gaming. I do not care about a gamut level of 92%,even thou I do desire nice colors,further on I don't give a damm about viewing angle or connections (one DVI will suffice) or HDCP. I desire no ghosting and the lowest input lag possible with nice colors! Maximum price around $1000 (doesn't really matter since I'm from Sweden)
Thx for any answer
I'm in the same boat, although $1000 is way too huge a budget for a TFT. I wouldn't restrict yourself to 24" either, just the 1920x1600 resolution for gaming. The video card doesn't care if its a 26" or 27", and you have a big enough budget. :)
Anything bigger than 24" is just unnessesary.plus that the display will be much more expenspensive for me in Europe. So can anyone give me a tip. A really fast monitor with nice colors? Thx
uh, no.
lg 24" is best 24" gaming monitor.
that's fairly obvious for about 10 reasons the soyo one is dried poop on a stick.
Hi all!
~El~Jefe~ do you mean the Lg 245 WP or the Lg 246 WH? [what's the difference?]
is it any good? Its way way cheaper than the Dell UltraSharp 2407WFP [/with "-HC" (whatäs the difference?)], at least here in Sweden. the 2407WF costs $1.360 and the Lg 245WP costs $940.
How is the Lg 245WP/246Wh :rolleyes: (confused) VS Dell 2407WF VS Benq FP241W VS Acer AL2423W
which of them are the FASTEST display, most suitable for Gaming that is!
As I said before viexing angle and input connections aren't important.
I would really really appreciate the help, many THX
