Best 22" Widescreen LCD???
I'm tempted by the 22" Westinghouse for $220 at Best Buy...
I doubt it's "The Best", but could be good enough for me and the price is nice!
That looks like a great deal (built in speakers too.) Does anybody have opinions or reviews of this LCD?
Also, what do you guys think of the Acer AL2223WD?
I had the Acer AL2223WD but took it back after using it for nearly two weeks because I couldn't live with the poor viewing angles and black crush. Color and text was very good on it.
is there anything else in the same price range you would suggest instead?
Probably not because most of the 22" LCDs use the same panel that the Acer uses. And they all use TN panels, so there's always going to be a problem with viewing angles. But if you can live with it then any of them are going to perform about the same.
Samsung 226BW. Doesnt much matter which panel (S,A, or C) because they all look about the same once calibrated correctly.
