Originally posted by tcompton2
OK, staright up guys what is the best 2.1 system you have heard...
Originally posted by DRJ1014
http://www.provantage.com/buy-22085270-logitech-speakers-z-2200-speaker-system-shopping.htm
this one is one of the 10 2.1 speakers that have a remote http://www.newegg.com/app/ViewProdu...atalog=60&manufactory=BROWSE&depa=1§ion=1
http://store.klipsch.com/details.asp?prodID=1
those are about the best out there.
Originally posted by Gluegun
Uhm... what are you guys talking about? The new Altec Lansing system whoops the klipsch / creative, etc...
MX-5021
MX-5021
first off how would we know all there is is a picture and nothing to read. you could say there good but they may actually suck. let us have a link where we can see the spec. also why would someone want to buy some speakers that have been discontinued? if they where the best they would keep them out. also i dont think anyone would want to buy used speakers.
Originally posted by agentzero9
Altec Lansing 621, though, you can only get them used as they've been discountinued.
take a look at these creative speakers http://uk.europe.creative.com/products/product.asp?prod=374 300 watts, 75 watts per satalite
Do you think specs mean everything?
Originally posted by BaldHeadedDork
Easy.
My Denon DRA-685 and Paradigm Mini Monitors.
Technically it's a "2.0" system (doesn't need a sub) and it cost $750...but you asked for the best.
BHD
Originally posted by leukotriene
They definitely do not, especially in this particular category of "hi-fi" equipment, but the Creative 250D's are quite good for the money depending on what type of music you typically listen to.
Certainly both are going to be inferior to a decent 2.0 component system in the middle and upper octaves, like the Paradigm Minimonitors BHD uses.
The thoroughly acclaimed Swan Diva's mentioned in this thread by GMC are much more tempting for $150 than either the MX-5021, the 250D, or the PM2.1s.
spec are everything. you dont buy anything with out looking at the spec. with speakers if u didnt look at the spec u might be buying 10watts when you really want 70.
i was talking about these
Originally posted by Hightreason
Well im assuming the question was about computer speakers. If you want to head down that road we can talk about the wilson watt puppy+watchdog system for 50 grand. But if we're talking about computer speakers i'd have to say the now discontinued monsoon planar speakers
