Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm looking for a silver one to complement my new Alienware system for gaming, but I have no clue which is best brand, but I've heard the lower the ms the better an lcd is. Hopefully not too expensive, I'm on a tight budget.
1.) Use the search button, you will probably find what you want to know
2.) You need to post how much you are looking to spend
3.) Alienware ripped you off
I will get the viewsonic black one..it will match my black alienware....and also the other viewsonic 20 inch monitor 16ms got some really good reviews..so i say this new monitor will be better.. and plus the reponse time is 12ms
