Best 1600x1200 resolution display?
AVT
I'm trying to find display to upgrade to from my 1280x1024. I don't like widescreen, so I'm not interested in that.
Unfortunately, I can't seem to find any displays with a non-big response time anywhere, and those that I do find are significantly more expensive than what I'm using now cost 4 years ago.
Does anyone know of any?
If you like TN panels, get a Sammy 204B. It is a freakin' FAST 20"er. I loved mine for a long time. Still got it, but my 245BW and now my 305T replaced it. IMO the 204B is def. the faster 20"er out there. No lag at all. Viewing angles are not real great, but that's a TN thing. FWIW.
Assuming you win the panel lottery on them and get an IPS panel, the HP LP2065 and Dell 2007FP are the highest quality 4:3 panels that you can still find easily these days.
Both use the same IPS panel, but if you game the 2007FP is probably slightly better due to having very low input lag.
If you plan on buying either, there's some more information about them in this thread.
16ms is over 3x the input lag I currently get. I'm looking for something in the 5-7ms range.
The 204B seems like a good match, but I can't seem to find it anywhere. Neither Newegg nor any local B&M stores seem to have it, and I don't really want to buy it from eBay, due to dead pixel luck.
I've got a 204b and its a excellent panel. Not sure where you can still get them though, as 4:3 panels seem to be getting pretty rare these days. I'll be keeping mine for quite awhile (although I might add a 24" as a primary panel now)
