blackstang281
- May 5, 2012
Hello, first post here
Currently I have a NZXT switch 810 with a coolgate 420mm rad mounted in the top of the case with 3x140mm aerocool shark fins pushing (96 cfm) and 3x140mm prolimatech blue vortex pulling (87cfm). I have blowing air in a coolermaster 140mm fan in the rear spot, and 4 x NZXT (62.5cfm) fans at the bottom front and front fan spots. Rest of the system in sig. The "problem" I am having is when folding over night my temps get up to the mid 50s on both the GPU and CPU, case temps get up to around 35c and the air coming out of my radiator is quite warm. So I believe I do not have enough airflow across the radiator, and also possibly not enough airflow into my case. I am looking to upgrade the radiator fans or atleast get 3 more aerocools pulling so I have 6 of the same fan on the radiator. I have been researching 140mm fans pretty in depth lately, and it looks like the aerocool shark fins are a pretty good choice with high static pressure. Any other options out there?
