Best 120mm fan?
Mabrito
My HP desktop has been getting warm inside when im gaming and the processor goes up to 60 degrees when im playing games on it. It only has one fan in it and its a 120mm in the back. Its not that powerful and barely pushes air through it. So what is the best 120mm fan out there that has the highest RPM and pushes the most air. Noise factor is not a problem. Im probably going to get 2 and rig one if the front, so one blows in and one blows out.
If noise is not a problem, I would suggest a ys tech 120mm, I believe they flow 105cfm, and are 120x120x25 so they will fit in any location designed for a 120mm. Whereas some higher cfm fans are thicker than 25mm, so they may not fit into retention brackets, or get in the way of other things.
