sladesurfer
- Feb 4, 2006
I want to know what's the best 120 Radiator out there????
thanksBbq said:low-cfm fan: Thermochill HE 120.1
high-cfm fan: Thermochill PA 120.1
Cheap alternative: Black Ice GT 120.1 (about half the price of the thermochill's,NEARLY as good.
Bbq said:low-cfm fan: Thermochill PA 120.1
i wouldn't go so far as to say it was "garbage". i think it was just a flip around mistake.chris.c said:Garbage post.
Thermochill HE is designed for high CFM fans, where as the PA is designed for low CFM fans. Regardless, the PA is a better radiator no matter what cfm your fan is.
As for your cheap alternative suggestion, at 600rpm fan speed the PA is NEARLY *twice* as good as the black ice GT. You get what you pay for.
stormshadow said:i wouldn't go so far as to say it was "garbage".
rjblanke said:... there's no reason not to get the PA.
True, in that case, BIGTS is pretty good.stormshadow said:as i mentioned earlier, space could be a deterrent... PA's run almost 6cm in thickness
SiGfever said:Go ThermoChill or go home.
ThermoChill Rocks!
