What I'm looking for is the highest resolution with 120 Hz enabled along with a large display, 27-30", and good colors, preferably close to ips standards.
Does it exist?
So true. For reference, 120ish FPS in BF3 requires a 580 @ 900 MHz, Ultra textures and terrain detail, medium shadows and fxaa, low everything else, hbao off @ 1080p on a 3.5Ghz i5 760. 8+ GB ram helps too, but that's cheap. 680 at stock ensures minimum is 120, but 580 is more than enough to see benefits.Something important to note... It takes serious hardware to push 120fps if you play a lot of the newest games and want all the eye candy. It's pointless to pick one up if your hardware can't push past 60fps. It's not as simple as picking out a 120hz monitor and having a older crap video card.
I don't ever see this mentioned....
The 27 inch Asus 120 htz is a matte screen. It is also totally adjustable in height and direction. It is a TN display. Viewing angles are important and you have to sit directly in front to get the best picture. It would not be a monitor I would use for extensive photography work, it is really designed for gaming with a fast video card. it comes with the nvidia 3D glasses. 3D varies a lot of course, but I have seen some good 3D so far with my GTX 580. So really in my opinion, if you game a lot or browse the internet, it's a great monitor, otherwise a high end IPS may be better for you.
Norm
noDue to the limitations of the bandwith of DL-DVI-D the highest 16:9 resolution you can achieve at 120Hz is 1920x1080
no
dl-dvi is even good for 2560x1440@120hz
confirmed in one of the catleap threads
