Best 1 - 2TB external hard drive
Robert_J
Ive never looked into external hard drives but I think one could be a convenience for me for all kinds of things such as school, media, easy transport etc.
I dont know what brands are good though and what brands i should stsy away from
help me out
thanks
Buy a 1 or 2 TB Western Digital Green drive and a USB/ESATA enclosure and make your own. I have a Rosewill enclosure that works well and I have no complaints.
Don't get an enclosure or external that only has usb 2.0, you'll get old waiting for transfers.
Get something with e-sata and/or usb 3.0.
As to brands for externals, I've heard that it's a good idea to buy HD manufacturer brands - the 3-rd party ones might be using refurbished drives inside. But I'm not sure about it.
I also reccomend getting an enclosure + hdd, maybe you'll find an enclosure with a fan if you desire. You'll also likely get more warranty out of the drives, for example WD Elements only has 1 year, while their MyBook has 2-3 years depending on model. Most bare drives have 3 years warranty.
But it depends on what you'll find for what price.
