bent pins
atlrocks07 said:
whats are my chances if i bent some pins and they got into the motherboard socket.
Do you mean BROKE some pins and they got into the socket? Im totally lost.
Pins are meant to go into the socket.
Hmm, I think I follow what you are asking.
If you have bent pins on a cpu and insert them into the socket, they could bend further and potentially break when you try and straighten them after.
If they fit into the socket while bent, they could get stuck when trying to remove the CPU later.
This could allow the pin(s) to get ripped off.
Both the above scenarios are likely to result in an unusable CPU.
Use a pair of long nose pliers to straighten the pins gently before inserting the CPU.
The CPU should drop into the socket cleanly.
A slight wobble of the cpu is ok to get it to fit but anything more requires the pins to be straightened.
I've found that if they are close enough to straight to fit into the socket in the first place then the socket will straighten them out further.
yeah, the socket does straighten them a bit but not always enough.
I've come across a few cpu's that needed extreme force to get them out of the socket from bent pins being pushed in the socket and getting wedged in.
I feel dutybound to point out the worst case (and a quite possible) scenario, otherwise if my advice is used and it breaks, I'll feel crappy.
this is typically my experience
Yea but I was assuming he meant bent pins that still slid in easy with zero force into the ZIF Socket. NEVER apply force to a ZIF socket. If the pins slid in with no force then it will come out with no or next to no force. OP, do NOT push the cpu in. Straight the pins best u can until the cpu slides in with no problem. But still you've not responded with what you meant with your question in the first place so I cannot give you better advice than this.
i bent some pins on my new 4800+ cpu..i just want to make sure there not a half of pin in my socket..because i sent my cpu back for a new one. and i dont want to mess up my new mobo and cpu with i put it back in.
you've got one option. take the motherboard. open up the lever and shake as hard as u can. if there is a pin in there the force of u shaking along with gravity will get it out. also, u sent back a cpu u bent urself? come on man thats not cool homie that just raises the cost of cpus for the rest of us. if there is a piece of pin in there u will know it when ur cpu doesnt slide in. if ur cpu slides in easily then there is no pin in there.
can you crap 300 dollors for a new cpu..i cant.
i just got the cpu motherboard and video Monday afternoon
broke the cpu that day
thanks to newegg i was able to get a rma
if they see a broken pin n dont see the pin in the container they will assume (rightfully so) the end user broke it themselves therefore they will tell you your warranty is void and will not replace ur chip nor will amd. rmas simply are the very first step. an rma doesnt mean they will replace it
QFT man. Read on the forums here about a person who RMA'ed his video card. Newegg refused the RMA because the little serial # sticker was not on the card when they recieved it.
if there was absolutely no other way to identify the card, newegg was correct. that card could have been bought anywhere. could the sticker have said "void if removed"?
even if the sticker is removed and placed in a different location it voids the warranty with newegg.as far as ive seen the serial sticker pretty much always warns of voiding warranty upon its removal.
if someone had two cards they could just switch stickers which is the main reason that the warranty is void if u remove it. upon careful examination its not too hard to see if a sticker has been removed before. kinda sucks for the end user but the end user still has their option of trying their luck with the manufacturer directly.
